Most folder diff tools allow you to jump to the next difference in the next file with the same key as Next Difference. E.g. I have F3 mapped to Next Difference. I should be able to jump to all diffs across all files in the folder compare by just pressing F3. Instead when I reach the last diff in a file, F3 simply does nothing, rather than goto the first diff in the next file.
Even worse, if I close the current file diff with ctrl-F4, now the active focus is nowhere meaningful in the folder diff view. Pressing any of tab/shift-tab/F3/down arrow will not move to the next file to diff. Arrow keys to navigate the folder diff view and Enter to diff the highlighted file need to consistently work. The only way this seems useable is using the mouse to select files in the folder diff view and then pressing Enter (or double clicking) to diff the files, which is cumbersome for many files.
What am I missing?
What am I missing?
