What are STCD files?
6
PostAug 02, 2021#1
I try to understand the UltraCompare Synchronize Folders function.
The help screen for it refers to STCD files although that pane on my version of UC for Windows (21.10.0.18, 64-bit) doesn't include a rule for them.
What are they, and does it matter that they're absent from the Rule Customization box?
PostAug 03, 2021#2
The abbreviation STCD is explained at bottom of the power tip Sync files and folders with UltraCompare and means Same Timestamp, Content Different.
6
PostAug 03, 2021#3
Thanks!
Or Danke!  because, Austria.  :-)
So if I understand correctly, the current version of UC has renamed that to "Diff" but with the same meaning as STCD.
