How to do a Quick Compare of 2 directories?
    Apr 10, 2010#1
    Quick Compare works fine, when comparing 2 files.
    Example:
    uc -qc "F:\1\New.txt" "F:\2\New.txt"
    Same
    But how can the UC program (UltraCompare) do Quick Compare for all files and all folders in a directory?
    The desired end result after comparing 1000's of files in dozens of directories would be something like this: (-d = directory)
    uc -qc -d "F:\1\" "F:\2\"
    Same
    Background, using:
    Win XP Pro
    UltraCompare version 7.00.0.1018
    6,685587
      Apr 10, 2010#2
      There is no quick folder compare option. You can use the following batch file. For a description see the comments which are the lines starting with command rem.
      @echo off
      rem Run a full binary recursive folder compare with not equal results written into a text file.
      uc.com -fb -dmf -r -d F:\Temp\Test1\ F:\Temp\Test2\ -ne -o F:\Temp\Result.txt
      rem Check if a binary file is listed in the results file because of a difference.
      %systemroot%\system32\find.exe /c "| Binary    |" F:\Temp\Result.txt >nul
      if errorlevel 1 goto !CheckText
      rem Different binary file listed in the results file.
      echo "DIFFERENT"
      goto !Exit
      :!CheckText
      rem Check if a text file is listed in the results file because of a difference.
      %systemroot%\system32\find.exe /c "| Text      |" F:\Temp\Result.txt >nul
      if errorlevel 1 goto !CheckEmptyDir
      rem Different text file listed in the results file.
      echo "DIFFERENT"
      goto !Exit
      :!CheckEmptyDir
      rem Check if an empty subdirectory exists in one folder and not in the other.
      %systemroot%\system32\find.exe /c " none " F:\Temp\Result.txt >nul
      if errorlevel 1 goto !AllEqual
      rem Different empty subdirectories in one or both folders.
      echo "DIFFERENT"
      goto !Exit
      :!AllEqual
      echo "SAME"
      :!Exit
      del F:\Temp\Result.txt >nul
        Apr 10, 2010#3
        Hello Mofi
        Thank you for this idea.
        But there is 1 thing that did not work for me:
        " none " in CheckEmptyDir does not work for me because " none " exist when directories ARE the same.
        Here is what is being tested....
        @echo off
        uc.com -fb -dmf -r -d "f:\1\" "F:\2\" -ne -op "F:\TemP1.txt"
        :!CheckText
        C:\WINDOWS\system32\find.exe /c "| Text" "F:\TemP1.txt" > "F:\TemP2.txt"
        if errorlevel 1 goto !CheckBinary
        echo Different - Text
        goto !Exit
        :!CheckBinary
        C:\WINDOWS\system32\find.exe /c "| Binary" "F:\TemP1.txt" > "F:\TemP2.txt"
        echo Different - Binary
        goto !Exit
        :!CheckEmptyDir
        C:\WINDOWS\system32\find.exe /c " none " "F:\TemP1.txt" > "F:\TemP2.txt"
        echo Different - Directory
        goto !Exit
        :!AllEqual
        echo Same
        Pause
        :!Exit
        Pause
        6,685587
          Apr 11, 2010#4
          I'm using UC v7.10.0.1012. This version does not write equal directories into the results file with word none. Command line parameter -ne should result in having only different files and folders in the results file. The word none should be present only in the results file when either a subdirectory or a file exists in only one of the 2 directories. For the tests I have done this works.
