Rectangular select
Rectangular select
Cemil
    Mar 19, 2005#1
    Does anyone know if it is possible to make rectangular select in UE ?
    I know that it is possible to make a Select Range.
    But is there not a quicker way, like other editing tools where you hold down ctrl and moving the cursor or something similiar ?
    Hope someone has a solution.
      Mar 19, 2005#2
      Try 'Column Mode' in the Column menu. This should hopefully give you what you need.
      63
      Advanced UserAdvanced User
      63
        Mar 21, 2005#3
        Hi Cemil
        Column mode is a toggle (On/Off)
        There is a icon on the tool bar or use the keystroke Alt+C
        Use your mouse, while holding down the left mouse button, to select a rectangular area or hold down the shift key and use the arrow keys.
        I love column mode, but you really have to play with to understand it! Check out the different behavior with Insert on and off, interesting!
        Have fun
        Cemil
        Cemil
          Mar 21, 2005#4
          Thanks a lot.
          It works great.
          From Cemil
          25
            Feb 01, 2007#5
            On the same subject...
            I was wondering whether this editor could be configured to do rectangular selects / copy / cut / pastes just by doing a tripple mouse click (or quadruple as in gvim common setup) to initiate the selection.
            (I disliked many things in gVim but the above was very intuitive to use; no modes to think of.)
            Thanks in advance,
            vhdlguy
            206
              Feb 01, 2007#6
              Man, I'd much rather click a Column Mode toolbar button than do a quadruple mouse click! :)
              Software For Metalworking
              25
                Feb 01, 2007#7
                I admit, it took a little practice. Also, there was certain ongoing "failure rate" but no grave consequences.
                I would like if the column mode still allowed us to do selections by clicking (and dragging if desired) on the left sidebar, the one with line numbers. Then I would never leave column mode.
