All,
I recently started using UE on 64-bit OpenSuSE. While it is nice that it keeps previous versions of files in your directory, it would be nicer if there was a tool or option one could select from the toolbar or menu to purge all prior versions of a file. I'm very used to file versioning since I worked on OpenVMS all my life, but there versions were ;nnn and you simply issued PURGE/LOG *.C/KEEP=2
Has such a utility been provided for UE?
