Dear readers,
I notice that the function "XML convert to CR/LFs" does not work for read-only files
The function is disabled.
While I realize that it cannot be saved ( since it is read-only ) I'd still like to have the possibility to re-organize the XML file to easier read it. Then it is up to me if I save it as a different file, or discard the changes.
Typical situation is when I fetch an XML file out of a ZIP file. It then is un-packed by the zip-file reader to a temporary location, and is set to read-only.
Is this just me, or is this a general opinion that it should work ?
Kind regards
JoernH
Kind regards
JoernH
