Hide all except selected lines
15
    Apr 29, 2005#1
    Is it possible to do the inverse of selecting "Hide/Show Selection" where all the text not selected should be hidden?
    In a large text file, I'd like to be able to work on only a small segment of it and not worry that I may modify some other text.
      Jul 30, 2006#2
      Yes, with a macro which hides everything above and below the current selection. The answer is very late, but maybe you are still waiting for one. Here is the macro which will do that.
      IfSel
      Cut
      "STARTOFSELECTEDBLOCK"
      Key HOME
      IfColNumGt 1
      Key HOME
      Key DOWN ARROW
      SelectToBottom
      IfSel
      HideOrShowLines
      Find MatchCase Up "STARTOFSELECTEDBLOCK"
      Key HOME
      IfColNumGt 1
      Key HOME
      Key UP ARROW
      SelectToTop
      IfSel
      HideOrShowLines
      Find MatchCase "STARTOFSELECTEDBLOCK"
      Delete
