I've just purchased UltraEdit (version 20.00.0.1056) after many years with PFE32 (and VDE before that).
I'm trying to use word wrap and numbered lists.
Here's how I've configured word wrap:
Advanced | Configuration | Editor | Word Wrap/Tab Settings
Wrap method:
Default word wrap on for each file - CHECKED
Wrap after column #, insert CR/LF
Wrap column #: 70
Question 1: Automatic word wrap on the paragraph as it is edited
I type a long line:
It's one sentence, displayed on two lines.
Then, I insert a word I omitted, "forth", on the first line.
The first line wrapped to two lines, leaving a third line.
This is a single paragraph. I'd like to have it wrap to column 70 as I edit the text without creating a superfluous third line.
Can this be done automatically, without needing to press Ctrl+T to reformat the paragraph?
Question 2: Automatic word wrap of the paragraph after insertion of an indentation
I'll add a third line.
I'll number the paragraph:
I'll try to indent the second and third lines with all the lines wrapped at column number 70.
It should look like this:
If I insert an indent of 4 spaces on the second and third lines (select the two lines | Format | Add Indents | 4), the lines are not wrapped to column 70 after the indent is added:
How can I produce a numbered list with indentation and respect the wrap at column 70? (Is indentation the wrong way to do this?)
TIA.
regards, AndyA
Wrap method:
Wrap column #: 70
I type a long line:
Four score and seven years ago our fathers brought on this continent,
a new nation, conceived in Liberty
Four score and seven years ago our fathers brought forth on this
continent,
a new nation, conceived in LibertyThis is a single paragraph. I'd like to have it wrap to column 70 as I edit the text without creating a superfluous third line.
continent, a new nation, conceived in Liberty, and dedicated to the
proposition that all men are created equal.Code: Select all
10. Four score and seven years ago our fathers brought forth on this
proposition that all men are created equal.It should look like this:
the proposition that all men are created equal.
TIA.
regards, AndyA
