I have a work laptop that is admin locked down so I cannot add/remove/change software.
Even the local hosts file I have to get elevated rights for to manage.
Last week my work pc was Re-imaged and UltraEdit was downloaded by it support remotely.
Until this week I was editing my hosts with notepad / vi (I also use Cygwin) but once UltraEdit was installed I switched over (I did not have a configuration to important just set the look and feel of the UI)
All seemed fine for a few hours until I got a Windows error the file was no longer there.
After troubleshooting with it I was able to edit and keep hosts fine but each time I opened in UltraEdit and saved the file vanished.
I checked UltraEdit config and delete before save us not enabled and can't see anything else that could be causing this (config wise).
Any ideas?
Any ideas?
