Somehow, when I'm using Ctrl+F to find, UltraEdit has several times now increased the font size massively on every single open file. I can see the font size increase rapidly over a second or two. It's not and instantaneous change - I can see them all growing - but it happens very fast.
I can fix this by View - Reset Fonts (default), but ... I 'd like to prevent this from every happening as I don't ever want to change my fonts accidentally - or ever really? Is there a setting where I can turn this off?
Also, resetting the fonts only fixes the current file. How do I reset the fonts for All my open files?
One other thing. Somehow when all this happened, UltraEdit changed my tab stops so that a single tab moves to column 20, then to 40. Is there a command to 'reset tabs' to the default?
Thanks!
Thanks!
