I work with large log files. They have some records that are longer than the viewing window of UltraEdit. I use the
"Format >>> Wrap to line ends" menu function to get those long records to wrap so that I can view the entire record in the window. In the past it worked with no problem, by that I mean the entire file's records that are longer than the view area get wrapped. I have noticed that now it does not effect all the records between the first and the last that are too long. Why is this? Is there something I must do because it is a large file (28,000 records, 3.58 MB)? If anyone else has experienced this and found a resolution can they share it in the forum. Thanks.
