- I have a text where lines 48 and 49 are longer than approx. 4100 chars and which are wrapped into the second line
- I want to remove the numbers 159-162 in the following lines 50-53
- I set the cursor in line 50 between " and 159
- I expand the select 4 lines down (until between " and 162)
- I press "delete" - 1 is removed four times, the selection is expanded upwards to line 49
- I press "delete" - 5 (1x) and 6 (3x) is removed, chars from line 49 are deleted too, the selection is expanded upwards to line 48
- I press "delete" - 6 chars from lines 48 to 53 are deleted
Screencast here:
https://autode.sk/2OAcSwb
Seem to be a bug ...
Screencast here:
