Intro
A custom configuration with selected functionality preset, revised menu layout, and optimized input shortcuts.
Purely focused on enabling the ultimate power while retaining the ease of access, to unleash the full potential of UltraEdit to the maximum extent possible: shedding light on functionality that's been there for long but left in oblivion, the unseen potentials. A new vision.
Preview the ultimate power:
(Backup / Restore User Customizations)
Further on the Vision
- Still blinking caret indicator(s) (on the editing document) with such context menus open.
- Including when focused on those "floating" "docking" "dockable" windows whatsoever. (e.g. "Find and Replace" docked on the right)
- Command palette open position references to the mouse.
- When opened at the edge of the screen (due to mouse position): if the following mouse movement (in 2000 ms) was (largely) towards the screen center, the palette shall follow it (moving to the center) for an appropriate extent.
- Afterward retain the current behavior (position remains fixed). Or probably making the palette somewhat resembles to the "floating" window? (maybe even configurable window size)
- Note: the distance highlighted on the image is 32 px (both X,Y).
- Command palette mouse-over (hovering) item highlight support.
- Like what's in "Find and Replace", "Regular expression builder":
(navigation via hovering/click on the button like item)- Off-Topic: Yes, it's apparently broken. (the \ character display escaping problem in the UI)
- Highlighting the related items (if present) in the opened context menu at the same time.
- Whether present or not, the item's description shall be reflected on the status bar.
- Weird whim: possible to implement some sort of limited extent multi-select (via the typical Windows shortcut: Ctrl / Shift / Ctrl + Shift + Click / Arrow Up/Down) functionality, for those "order insensitive" / "non conflicting" options? (e.g. "Split window horizontally" and "Split window vertically")
- The idea applies to other types of context menu too.
- Multi-frame multi-caret editing support.
- Active frame highlight indication. (in multi-frame view only)
- Note: the right/bottom border should appear in full length, when the next adjacent frame is not highlighted.
- The column ruler(s) shall correctly reflect the active column(s) for all frames.
- The app failed to do so on the focus switch between frames. (bug likely)
- Every pixel of available space shall be made of full use:
- There shouldn't be any point for that "little gap" to exist, near the end of the document view (both the edit window and document map). (also near the start of the document map)
- Also see: Document map.
- Optional flexible width for "Open address bar" when docked. (instead of using a pre-determined width)
- "Open address bar" always reflects the last active file. (see: Inspired by other apps)
- Two independent search inputs (non interfering), with shared search history.
- "Search options" control from the main input ("Find and Replace": "Find").
- "Find String List" adding a new sub-tab similar to the "1", "2" in "Output Window". (to handle the "Dual Find String")
- Expanded bookmark tags for wrapped lines. (see also: Line wrap handling)
- Probably color tinting on the column ruler(s) can also be utilized to represent bookmarks on the same line (of different column). (only when active on the bookmarked line, for the wrapped part only)
