How do you delete a template in the Template List (Ctrl+F9)?
5
    Sep 27, 2005#1
    I did look in the Help section and it said that the templates are stored in a file in the applications directory?
    What is the name of the file?
    Thanks!
    --Todd
    6,679585
      Sep 27, 2005#2
      The name of the file is Uetmplte.dat. But be carefully if you want to edit it, because it is not a pure text file. It contains also binary data. Modify it in hex mode. But first make a copy of the file.
      5
        Sep 27, 2005#3
        Thank you.
        Has there been any suggestion to make this 'user-friendly' to manage templates?
        --Todd
        10
          Oct 07, 2005#4
          you can always use an empty one to delete/replace an existing one. that is what I do. no need to edit the file directly in hex mode.
