Can't use "brace strings"
10
    Oct 07, 2005#1
    I am trying to add custmoized brace strings to VB part of the wordfile.txt.
    Without anything added there, if I press "Ctrl+b", UE braces around "(" abd ")
    However, if I add the following:
    /Open Brace Strings = "{"
    /Close Brace Strings = "}"
    I even lose the basic bracing of "(" and ")".
    Anyone knows how to specify some brace strings correctly? Thanks!
    6,680583
      Oct 09, 2005#2
      It's always a good idea to look on examples like C/C++ syntax definition in standard wordfile.txt
      /Open Brace Strings = "{" "(" "["
      /Close Brace Strings = "}" ")" "]"
      10
        Oct 10, 2005#3
        I see what is going on. The braceing won't work if it is behind the comment symbols. Is this necessary?
        Paticually for my case, I used to use ' { and ' } to brace a portion of code (just for quick navigation through a file) and it worked in UE10. Now, in v11, it is gone.
        6,680583
          Oct 11, 2005#4
          Check Advanced - Configuration - Syntax Highlighting - Brace Match In Comments (option in lower right corner).
          10
            Oct 14, 2005#5
            That is IT! Thanks! :P
