Compare Report Changes in UE-32
    Dec 22, 2005#1
    We recently upgraded to UE-32 v1.10. When doing a File-Compare in the new release I noticed the new functionality in UltraCompare Lite. These are all fine, except...
    I can't seem to save a comparison report that formats in the same manner as our prior release. Specifically, I am looking for:
    !> Line in file 1
    !> Another line in file 1
    <! Line in file 2
    <! Another line in file 2
    Line in Both files
    Instead of:
    * Line in File 1 * Line in File 2
    * Another line in File 1 * Another line in File 2
    Are there options/Settings that I am missing that would allow for the other format? Any help is appreciated - Thanks!
      Aug 08, 2006#2
      I have UltraCompare Professional v4.00a, so I don't really know if following option is also available in the Lite version:
      Options - Configuration - Backup & Save - Side by side result
      Turn this option off if you can see it in the configuration dialog.
      Note: Current version 4.00a of UltraCompare Lite also works with previous versions of UltraEdit down to v10.00. All you have to do is get the files ucl.chm, ucl.exe and ucres.dll from the current UltraEdit install package and copy it over the existing files of your current UltraEdit installation. Well, to get the 3 files you have to install current v12.10a of UltraEdit without overwriting the existing version. So it's not so easy to get the files for non experts without destroying the current UE installation.
