Hi everyone,
I am beginning to use the Advanced>Display/ModifyTemplates... and Insert Templates portion of UE. The question that I have is that when I go to insert a template, I find myself having to go back to the mouse to scroll down the list to get the entry I wish to insert. And if I do not want to use the mouse, I can enter a number from the keyboard and it will take me closer to the entry I wish to use, but I still have to go back to the mouse.
Example, If I want template 14, I can hit alt+A and then 1 but that gets me to 1 and from there I can not get to 14 without scrolling.
Is there a dialog/Tool box that will display all entries in the Templates section so I do not have to scroll and see only a few entries at a time? or how can I issue a specific number template with out having to go to the mouse to scroll?
