Does UltraEdit support validation of XML files?
    Jan 23, 2006#1
    What features does UltraEdit have when it comes to displaying XML files?
    Can UltraEdit validate XML files against a XSD file?
    Can UltraEdit display XML files in a table format with rows and columns?
    Bert-Jan
    6,683583
      May 28, 2006#2
      Bert-Jan wrote:What features does UltraEdit have when it comes to displaying XML files?
      UltraEdit is a text editor. You will see the XML files as text files, but with syntax highlighting which makes it easier to read and edit. You will have also a function list. See on this website the feature list of UltraEdit for additional general features.
      Bert-Jan wrote:Can UltraEdit validate XML files against a XSD file?
      No, UltraEdit is only for editing the XML files in text mode. You can only setup a tool for validating your XML files - see XML validation tool for UltraEdit32.
      Bert-Jan wrote:Can UltraEdit display XML files in a table format with rows and columns?
      No! UltraEdit has no WYSIWYG capabilities.
