Adding command Get File Name
    Jan 24, 2006#1
    I suggest to add:
    Get File Name
    in extension to
    Get FilePath
    Cheers
      Re: Adding a command
      May 27, 2006#2
      Where is a command Get File Path? What you are talking about and what do you really want?
      40
        May 27, 2006#3
        I guess sphinxmoro means 'Copy file Path/Name' command available in the right click menu of tabs.
        It's better to send feature requests to IDM by email.
          May 27, 2006#4
          There is no need to ask IDM for an additional menu command for getting the file name. A template can be used to get it. There are several template options for file names. See the chapter "Display/Modify Templates command (Advanced menu)" in help of UE/UES.
          Templates can be used with hot keys, with the template list view, inside macros and they are also present in the menus and can be added to the toolbars. I have created for myself some templates to get the file name info I need in the current situation and use it in my macros. I cannot use unfortunately these templates when writing macros for other UE/UES users because they maybe (surely) have not these templates.
