Is there a way to make UE name .bak files to another extension..? Like maybe if I want all my backup files to have .abc as an extension..?
No, except you "crack" the uedit32.exe with UltraEdit in hex mode and replace .bak with .abc. Have you noticed the backup configuration options at Configuration - File Handling - Backup?
I like the feature to append .bak and to save all backups in a specified directory on my temp drive and not in my project directories on the data drive holding my projects directories clean.
