I couldn't find this information after searching through the forum, but I thought it would already be available.
Does anyone know if there is a size limit for the Undo action to work?
For example, if I cut a large amount of text from my file then try to undo it later the text will not re-appear.
If there is a limit, is this a limitation built into Ultraedit or into the OS clipboard?
