indent whole line?
indent whole line?
5
    Apr 21, 2006#1
    Hi!
    Does anybody know how to indent a line wherever the cursor is at? For example (note: | is the cursor):
    (define abc
    (lambda () (+ 1 2 3)) |
    Then, pressing a key combination causes that line to be indented by one tab without me moving the cursor to the beginning of the line. (Note: ignore _, just to illustrate empty space cause HTML trims leading white spaces):
    (define abc
    __(lambda () (+ 1 2 3)) |
    And of course the vice versa. Really useful for programming, a feature in emacs I think (but I hate emacs, it's so confusing). Currently on trial version of UltraEdit v12. Thanks in advanced, I hope the example illustrates my question.
    13
      Apr 21, 2006#2
      Hello amazonpit,
      when you need to write formatted text in a post, you can use the code button, the one with the #; just select the text and press the button:
      (define abc
      I don't know exactly how to do what you want in a fast and clean way, there is an "Add Indent" function, but it requires to select the text, so it doesn't suits you; however, in my opinion, UltraEdit can do a quite good automatic indenting according with the file type you have if configured properly, maybe it could be another way of doing the same thing.
      Koko McCracken
      5
        Apr 21, 2006#3
        Thanks for the prompt reply. Yea, I guess so. That feature is not essential, but it's a nice addition and I thought I asked if it exists already. Thanks for your help, I appreciate it.
        344
          Apr 21, 2006#4
          OK , here we go:
          Make 3 macros:
          KEY_HOME:
          Key HOME
          IfColNumGt 1
          Key HOME
          LINELEFT1:
          "XXXUNIQUEXXX"
          PlayMacro 1 "KEY_HOME"
          Key DEL
          Find "XXXUNIQUEXXX"
          Replace ""
          LINERIGHT1
          "XXXUNIQUEXXX"
          Find "XXXUNIQUEXXX"
          Replace ""
          KEY_HOME is there to be sure to be at POS1 of the line, whatever UE settings are set.
          Bind those other 2 macros to e.g. Ctrl+Left Arrow / Right Arrow.
          Not the fastest one, but it works.
          BTW, it stuffes the line with BLANKS only. No tabs are respected.
          rds Bego
          13
            Apr 21, 2006#5
            While having coffee this morning, I've come to this macro conclusion:
            Key HOME
            Key HOME
            Cut
            It's a cheap and easy macro, and do the trick quite well, however it's a bit late because Bego had the solution already, however, I need to share it :P
            God bless the coffee
            Koko McCracken
            5
              Apr 22, 2006#6
              Wow, you guys are geniuses. :)
              Thanks a lot, exactly what I wanted. Awesome.
                Apr 22, 2006#7
                Is there a way to tell the macro to check if there's no tabs/spaces left in the first col, don't do the lineleft1?
                edit:
                nvm. figured it out. :D
                thanks anyway though.
                LINELEFT1
                ":-:PROCESSING:-:"
                IfCharIs 9
                Key DEL
                Find ":-:PROCESSING:-:"
                Replace ""
                344
                  Apr 22, 2006#8
                  Jup. That makes sense.
                  I didn't implement this because I can live with the "hard behaviour". Anyway it makes sense and should be done.
                  Hmmm, Maybe the performance is better with a short unique-string like "@#$" or sth. Lets try it out :-)
                  rds Bego
                  5
                    Apr 22, 2006#9
                    Hey Bego, for the KEY_HOME macro:
                    Key HOME
                    IfColNumGt 1
                    Key HOME
                    Why does UltraEdit requires two execution of Key HOME to move cursor to beginning of line? Is that a bug or something?
                      Apr 22, 2006#10
                      At Configuration - Editor - Miscellaneous you can specify with Home Key Always Goto Column 1 how the HOME key works.
                      If this option is set, Key HOME sets the cursor always at column 1 and a single Key HOME in the macro is always enough. (That's the setting I always use.)
                      If this option is not checked (=default, I think) AND your current line contains preceding white-space characters (spaces or tabs), the first Key HOME sets the cursor to the first non-white-space character in that line. Now the cursor is already at the first non-white-space character and a second Key HOME sets the cursor to column 1.
                      But what happens when the cursor is already at the first non-white-space character before pressing the HOME key first time?
                      It isn't hard to guess. In this case the cursor is set with the first Key HOME to column 1 and a second Key HOME will set it back to the first non-white-space character. So the double Key HOME in the macro of Koko_McCracken will fail in this special situation too.
                      Only Begos' HOME macro makes sure, that the cursor is at column 1 independent of the configuration setting and if the current line has preceding white-space characters or not and where the cursor currently is.
