Trouble viewing a file with the form-feeds
    Jul 20, 2006#1
    I have a unix file that I'm viewing in ue32. I want to see the file as one record per line, but ue appears to be breaking it up after it 'sees' a hex
    '0C' (there is packed data in the file). So, instead of having one line per record, I am seeing 3 lines per record because it is going to a new line after each '0C'. Again, I want to see each record on 1 line so it will be easy to do a compare on the files. Anyone tell me how I tell ue to not go to a new line after it detects a '0C'? By the way, the files I am looking at originate on a unix system.
    thanks
    6,683583
      Jul 20, 2006#2
      Open File - Print Setup/Configuration - Page Setup and set the code for Page Break to a value not existing in your file. Then close UltraEdit, restart it and load your file again. The form-feed will then be displayed as small rectangle.
