UltraEdit-32 v12.20 Released!
221
Site AdminSite Admin
221
    Oct 12, 2006#1
    Hi Folks,
    We appreciate your interest and support of UltraEdit-32.
    Just a short update to let you know that UltraEdit-32 v12.20 is now available.
    We would sincerely like to thank all our Beta testers whose feedback has helped us to enhance the new features in this release.
    The changes in this release include:
    New features in UltraEdit-32 v12.20:
    - SSH/Telnet Window
    - Multi-key mappings (sometimes called chords)
    - Auto-indent wrapped lines
    - Support for Windows x64 Shell integration
    - Ability to view and print Key Mapping from configuration
    - Support for Alternate Data Streams on NTFS Operating Systems
    - Support for dual monitors
    - Right-click Find in Files from Explorer in File Tree view
    - Spell check in "strings" or "comments"
    - Grouped undo option
    - File Tab Color Highlighting on a per file extension basis (optional)
    - Bookmark now includes column number with line number (optional)
    - Default the View As option for new unsaved files (config item)
    - Saving of folded lines is now optional (config item)
    - Showing of last line of fold in syntax highlighted files is now optional (config item)
    - Ability to see path to the INI file in config
    - Integration with Explorer now a configuration item
    - New Settings for Output Window (via right-click context menu):
       - Use spaces instead of Tabs
       - Show Tool tips
    - Change working directory if no files are open in directory
    - Mouse wheel scrolls window under mouse pointer
    - More...
    Thanks again for your continued support and interest in our products.
    Ian and Team.
      Oct 17, 2006#2
      What does this mean?
      penntap wrote: - Support for dual monitors
      12
      12
        Oct 17, 2006#3
        Some transparent changes were made for more dual monitor support. There aren't any new configuration settings for dual monitors, but the developers did tweak some things "behind-the-scenes" to somewhat optimize the use of dual monitors with UltraEdit-32.
          Oct 17, 2006#4
          Okay. I used dual monitors for a while now and never saw any problems, so I was wondering what this new feature is. Thanks.
            Nov 04, 2006#5
            With v12.20 also the tooltip bug of user tools and project tools 11-25 in the toolbar seems to be fixed. Till UE v12.10b UltraEdit always crashed on my Win98 SE with a crash dump when I moved the mouse over the icon of a user tool greater than 10. Since v12.20 this does not happen anymore and the tooltip is correct shown. Also the user/project tools 11-25 (tested only with user tools 11-13) are now working from the toolbar too.
