Any way to have more than 10 tools ?
40
    Nov 16, 2004#1
    Is there any way to have more than 10 tools ?
    I don't use projects (and don't want to) so I'm limited to 10 but need more. Tried to add one in uedit32.ini but it did not appear then.
    Any chance?
    Advanced UserAdvanced User
    80
      Nov 16, 2004#2
      10 is the max. Another 10 is possible with projects. I didn't want to use projects either, but now I load one project all the time just to have the extra tools. I've emailed IDM in the past to ask for more tools. I recommend you do the same if you'd like more than 10 in a future version. Personally, I don't understand why there's a limit at all.
        Mar 11, 2006#3
        Good news for you. UltraEdit v12.00 and any later supports up to 25 tools and 25 project tools giving you a total of 50 tools.
        80
        80
          Mar 13, 2006#4
          I just upgraded to v11 so I should be good for the free upgrade. :)
