Highlight/bookmark single file tab?
    Feb 24, 2007#1
    I have searched the forums and all of the functions in the menus/customise menu window.
    I usually have loads of files open, some have the same name (eg index.php/functions..) and it pains me every time i want to search for a particular file that I have been working on if I have switched tabs.
    Is there a way to highlight/bookmark a single file tab by changing its colour etc? I have tried to add a filename for a particular coloured dot (file type colour) but it was already highlighted as a php file.
    If this is not implemented I'll send support a request message.
      Feb 24, 2007#2
      You can only specify a tab color for a specified file (file name with . and extension). I think (never tried it), that file name specific tab color setting should be the first one in the list or you remove the extension from the other tab color setting. But this will not help if some of your files have identical file names.
        Feb 25, 2007#3
        Aye, I was just trying that as a possible "quick-fix".
