how to auto-refresh project file list?
    Mar 16, 2007#1
    If I add a new file in project folder, I don't find this file in project file list until I re-click the folder name.
    Please help me how to get projects auto-updating?
    :cry:
    6,683583
      Mar 19, 2007#2
      Which version of UltraEdit do you use?
      And can you explain step by step what are you doing?
      I'm not sure what you mean.
        Mar 19, 2007#3
        My question is if I use Windows Explorer to create a new file in a folder which is specified as UE32 project folder, in project file list box (on the left side of UE32 interface), it isn't refreshed at once. After I shrink and expand the folder again, the new file is being displayed in the list.
        It should refresh itself when a new file has been created in the folder of the project. Is it possible to set anywhere an auto-refresh option?
        My English is very poor and I use v12.20 release.
        Thanks for you help.
        6,683583
          Mar 19, 2007#4
          If you modify the list of files outside of UE then UE will not recognize it until it is forced to rescan the project folder(s) which is the case if you close and reopen the view.
          I think, there is no option to let UE scan the project folders permanently in the background to automatically refresh the project tab of the file tree view. This could be very bad for performance of whole computer environment.
          Maybe IDM could implement following enhancement:
          1. When UltraEdit gets back the focus after an other application has had the focus
          2. and the file tree view is currently open
          3. and the Project tab is selected in the file tree view
          4. then it should rescan the project folder(s) and update the view if necessary.
          This is a feature request which you must send by email to IDM support if you want it.
          I personally don't use the folder method for my projects and have rarely open the file tree view. So maybe I'm wrong with my statements above. I use the group method for my projects where I have to manually add every file to the project. I like this method more because I can control which files are part of the project and which are not. But for big projects the folder method is normally better. Using the group method means no automatical update of the project files and so I don't have the problem you have.
            Mar 19, 2007#5
            thank you very much!
