How to add UltraEdit to "SendTo"?
    Mar 16, 2007#1
    Is there a simple way to add UltraEdit to the Send To option for files in WindowsXP?
    I'd like to be able to open files without extensions (Readme's and such) without having to unzip them from archives and then open manually.
    344
      Mar 16, 2007#2
      Just create a link (to UE) in your "SendTo" folder:
      C:\Documents and Settings\gary\SendTo
      If you cant see it, check your explorer setting (hidden system files etc.), already discussed here in other posts.
      rds Bego
