UE 12.20 Want a simple hex editor, no smarts
    Mar 22, 2007#1
    Hi:
    This is a great text editor. But at the moment, I'd like to make a few hex edits on a file, and all the UE smarts are getting in the way.
    1. Is there a "raw" hex edit mode, no replacements of source bytes on file open and load?
    2. Is there a way to open UE in "normal" 8-bit byte mode, not Unicode?
    Thanks in advance.
    -- Roy Zider
    6,683583
      Mar 22, 2007#2
      There is a hex mode at Edit - HEX Functions - Hex Edit.
      If your file is a text file with Unicode encoding, or has mixed line terminations, or contains NULLs, etc., you would need to disable nearly all auto-detection and auto-conversion settings and later enable it again to force UltraEdit to open it unmodified and directly in hex edit mode.
      But there is a faster and more easier trick to edit a strange text file in hex edit mode without changing any configuration settings.
      1. Open a new file, enter a single space, save it with a new name, press left arrow key and switch to hex edit mode.
      2. Now use Edit - HEX Functions - Hex Insert/Delete and delete 1 byte to delete the single space or select the 20 and press CTRL+X to cut (=delete) the single space entered before to be able to switch to hex edit mode.
      3. While still in hex edit mode use now File - Special Functions - Insert File to insert your file to the empty file in hex edit mode. You will see that the content of the file is inserted without any conversion.
      4. Make your changes and save the file without leaving the hex edit mode.
      Edit: Since UltraEdit v14.10.0 there is an "Open As" functionality for Unicode and binary files to open any file in a specified mode.
        Mar 22, 2007#3
        Mofi:
        Very nice. I never would have gotten that in a million years.
        Having tried it, though, I realize this is asking UE to commit an unnatural act. I'll have to find an upgrade to debug.com if I want to do any serious hex editing.
        Thanks again.
        -- Roy Zider
