How do I maximize my viewable code window?
5
    May 03, 2007#1
    I was trying to get a maximum view of my code within the UE window.
    So I right-clicked and hid the toolbars.
    Now I can't figure out how to make them come back - right-clicking at various places doesn't bring up the toolbar display options, and I can't find them in the menus.
    How can I redisplay my toolbars?
    [EDIT - Fixed this: It's View --> View/Lists --> Toolbars --> ...]
    [EDIT - my second question still stands though:]
    Second question: is there a fast way to get maximum view of my code? What it is is that:
    - I'm on a small single display screen
    - I have the text files I'm analysing in one window
    - I have UE open in another window, and I want to tile my windows to view both at the same time (so UE's "full screen view" isn't appropriate to me because then it's the only thing I can see, and my text files window is hidden)
    - What I would like is something like the "full screen view" but in a resizeable window, then I can resize to my heart's content
    344
      May 03, 2007#2
      Got German version here only. View menu, 3rd last entry: View full screen or so.
      This is only visible if you have switched to advanced menu.
      Therefore right click on the menu.
      rds Bego
      5
        May 03, 2007#3
        Hi Bego,
        In my original post I explained, "and I want to tile my windows to view both [the UE window and the other window] at the same time (so UE's "full screen view" isn't appropriate to me because then it's the only thing I can see, and my text files window is hidden)"
        344
          May 03, 2007#4
          Ah, sorry, have overlooked that.
          No. Only one full view windows is yet possible.
          I think you have to write a feature request to IDM.
            May 03, 2007#5
            Have you already disabled everything you don't really need when you want to see as much as code?
            Disable all special views and lists, disable the ruler with View - Display Ruler and disable the line numbers view with View - Display Line Numbers. In the configuration dialog disable code folding at Advanced - Configuration - Editor Display - Code Folding and uncheck also Enable show/hide lines for non syntax highlighted files, change the bookmark style to Pre-version 11 bookmark style or newer name Highlight entire line at Configuration - Editor - Bookmarks. Now you have full width for your code.
            To increase the height for your code, disable the open file tabs and the toolbars or use a single line toolbar (Basic toolbar or a customized personal toolbar like I do) with small buttons (icons).
            Nearly everything you can change via the menus can be done also with a hot key for fast enable/disable.
            But there is no "full screen in current window" option. Switching to print preview could maybe helpful here when you don't need to edit your code.
            5
              May 03, 2007#6
              Thanks, I think the answer lies in what you said, "Nearly everything you can change via the menus can be done also with a hot key for fast enable/disable."
              For me, the useful ones to disable (and later re-enable) are the height ones:
              - status bar
              - toolbars
              - filetabs
              I can disable/enable those from the menus, so I just need to set up each using hotkeys, then I'd just do something like:
              Alt-POI
              to disable it all
