Bookmarks moved
Bookmarks moved
13
    May 25, 2007#1
    when I open a text file with UltraEdit (version 11.10+1), which contains bookmarks, previously set by UltraEdit, sometimes I find those bookmarks moved to another line. I didn't open the text file with another editor intermediately.
    1. What may be the reason for it, i. e. on which conditions a bookmark may be moved to another line?
    2. How can it be avoided, that a bookmark is moved when opening the text file a further time with UltraEdit?
    3. By the way: How/where such an UltraEdit bookmark is saved in (or for) a text file?
    Thanks for good hints.
    Thomas Wiedmann
    344
      May 25, 2007#2
      Hallo Thomas,
      You can watch here where bookmarks are stored (it was a simple search in the forum): Where are the bookmarks stored?
      Are you sure the files are not modified meanwhile by other applications / processes ?
      Do you use multiple INI files? This would explain many things.
      rds Bego
      6,683583
        May 25, 2007#3
        UltraEdit stores for every bookmark the decimal byte offset in the INI file for the file which looks like:
        [Bookmarks]
        F:\Temp\History.txt=178,234,1284,-1,
        -1 marks end of list. So if you modify the content of the file with a different editor, the bookmarks will be on a different line when bytes are inserted or deleted before the saved bookmark byte offset.
        262
          May 25, 2007#4
          The format
          [Bookmarks]
          seems to be for earlier versions, like 11.10+1 used by ThWiedMann - right ? or maybe an alternate format to this:
          I have some files with saved bookmarks, so I checked the INI and for UE13.00a+2 the present format seems to be:
          [Bookmark Names]
          C:\temp\temp13.txt=jr1,
          [Bookmark Cols]
          C:\temp\temp13.txt=0,-1,
          [Bookmark Lines]
          C:\temp\temp13.txt=2057,7,-1,
          2057 is the total number of chars in the file. And from there on it is line numbers starting from 0, with -1 ending the list.
          If you only add or delete contents on existing lines with other programs, the "line bookmark" will be preserved in place. Adding or removing lines will cause the bookmark to be displaced.
          Of course if you also use "bookmark cols" these will be displaced when deleting/inserting in front of the bookmark in other programs.
          So as Bego and Mofi hints, never change files with saved bookmarks with other programs and be sure always using the desired INI.
          6,683583
            May 25, 2007#5
            jorrasdk wrote:The format
            [Bookmarks]
            Right!
            Optional saving the column number with the bookmark was introduced with UE v12.20.
            Named bookmarks are possible since UE v12.10.
