No undo in HEX mode?
    Jun 11, 2007#1
    Hi everybody,
    Can I undo the changes in hex mode? It seems that UE doesn't allow me to do this and that's very inconvenient.
      Jun 11, 2007#2
      Yes, in hex edit mode undo is not possible. Editing in hex edit mode is working like in text edit mode without temp file. I often must work in hex edit mode and after every important modification I save the file before I continue. This gives me the possibility to undo changes with File - Revert to Saved when I make a mistake and detect the mistake immediately (for example macro was not correct, replace all made to many changes, etc.).
