Hello all,
I've checked the forums and I don't really see an answer to my question so here goes...
I've got a ton of XML files that contain, among a bunch of other things, CDATA elements... I would like to find a way to be able to use the Format -> XML Convert to CR/LFs feature of Ultra-Edit to clean up the XML without affecting the text inside the CDATA sections. These CDATA sections contain pre-formatted text that needs to stay in the format that it is in so when I use the XML Convert functionality it always pushes all the CDATA text back to character position 0 so I always have to go back through the CDATA to put it back right. Is there a way to configure XML Convert to ignore the CDATA sections when reformatting the XML?
I'm running UEStudio v10.10.0.1012
Thank you!
Thank you!
