Can "Ignore with" have multiple entries
    Jan 25, 2013#1
    I would like to indicate there are multiple line starts which I would like ignored.
    For example if I want to ignore lines that start with 'abc' or '123' can I specify that?
    If so, what is the syntax?
    spaceBAR
    26
      Jan 25, 2013#2
      Yeah I can't figure out what delimiter to put between the strings either, Check out the attached image.
      If you figure it out please post solution.
      UltraCompare - ignore lines that begin with specified strings
        Jan 26, 2013#3
        I'm quite sure, that it is not possible to specify more than one string for each Ignore Lines which option.
