Hi Folks,
We are very pleased to announce the release of v3.50 of UltraCompare Professional. This also has some great new features and we think you will like the new "Relational-Line" view that gives a much improved graphical representation. We have much more planned for the future.
New features for v3.50 include :
* UC Text Relational Lines Mode
* Text block merge implementation as well as Undo Merging feature
* Ability to Edit Line and Merge within UltraCompare
* User Profiles for allowing different settings for different modes
* Copy selected lines to clipboard
* Split screen to preview text in one pane while moving from file to file
* Toolbar customization
* Updated Configuration dialog and enhanced controls
* Extended options and capability to ignore whitespace, blank lines, case, in folder mode
* More...
We are also very pleased to announce the release of v12.00 of UltraEdit-32. We think this release has several exciting new features that will be particularly of interest to long-time users. We have a lot more planned for the future and are already looking at the next release.
New features for UltraEdit-32 v12.00 include:
* Perl-compatible Regular Expressions / Real Unix-style regular expressions
* FTP/SFTP Enhancements
o FTP Accounts shown and accessible in File Tree View
o FTP Settings may now be in user definable file
o Ability to link local folder and remote folder and upload/download files between remote server and local system
* Find / replace enhancements
o Much improved UNICODE support
o Dialogs have full UNICODE support
o Highlight all found occurrences of string
* Auto-recovery of modified files after system/application crash
* Multiple backup files/versions on save and/or auto-save
* Increased User and Project Tools to 25 each
* New Macro commands:
o *IfFTP to check if file is an FTP file
o *IfCharGt to check if character is greater than value
o *IfColNumGt to check if column number is greater than value
* New improved dialog for User and Project Tools
* Improved (Aspell) Spelling Support
* Code folding support for ignore strings and comment strings
* Enhanced support for UltraCompare Professional including 3-way compare
* Right-click compare from UltraEdit File Tree View
* All menus and toolbars switch together when changing user profiles
* More...
Thanks for all your continued interest in our products!
Thanks again,
Ian
* More...
* More...
Thanks again,
Ian
