Yes, if you have a printer installed which saves the result as file in RTF, HTML, PDF, etc. and you print to this printer. UltraCompare itself does not support saving a compare result in RTF, HTML or PDF format which support hidden formatting tags and styles.
Thank you. That was very helpful.
Next item: I am now printing the results page to Adobe ro preserve the color edits, but some of the data is quite long on some lines and it gets cut off. I selected 92" x 92" and still run out of room. I tried to modify some of the settings but it wouldn't let me. is there a way to add a customized setting like 400" in width?
Well, I found an answer to my question. In the advanced settings, there is the scaling function. I was able to fit all data on a 92" x 92" page at a scale of 18%. Then to view it works fine at 800%. It's a round about way but it works.
