I routinely compare .bin files (firmware images). However UC 7.10.0.1020 no longer seems to work right in either (fast or smart) binary compare mode. All I get is two blank panes even when I know there are differences.
If I compare two text files, in text mode, everything works fine. If I change to binary mode, with the same files, I get the same blank panes.
The only solution seems to right-click in one of the file panes and select "Refresh". Then the binary data, and differences, show. Seems buggy to me.
