I generally prefer to run UE without dockable tabs enabled. This works fine in most cases, except when I wish to see multiple files simultaneously. Dockable tabs do allow for multiple side-by-side viewing, but I cannot find a way to view different files in an over-under style.
Without dockable tabs turned on, is there a way to view different files (not a split view of the same file) in an over-under style? And even better, in a side-by-side/over-under fashion (4 files in a square)?
If not, I think this would be a good new feature.
Also, I use multiple monitors, it would be great if I could find a way view multiple files over multiple monitors (without the oddity of spanning the main app window across both monitors or running multiple copies of UE).
FYI: Ver 16.10 of UE
dabbink
dabbink
