I use the font MS Reference Sans Serif, 8pt. In my texts I use blanks for identation and tabs, always 2 blanks. The text is always correctly indented and the lines show exactly under each other. Also the tabs always show perfectly under each other. This worked fine although this is not a fixed-sized font (its a proportional font).
Since I currently updated from v16.xx to version 17.20.0.1014, this is broken. The indentation works, but the tabs are not right. Maybe I didn't set the configuration properly or perhaps there is a new configuration setting. But I didn't see anything.
Can you please help me fix this?
Thanks alot.
Thanks alot.
