Thanks for the screenshots. They were really helpful to understand the wanted feature.
There is no built-in command in currently latest UltraEdit for Windows v27.00.0.54 for this type of HTML element selecting as far as I know.
I suggest to read my post
Highlight matching HTML tag explaining what to modify in used syntax highlighting wordfile - default:
%APPDATA%\IDMComp\UltraEdit\wordfiles\html.uew - to change default behavior of command
Select to brace for HTML. I use that definition for years and so did not recognize yesterday that the default behavior on using
Ctrl+B inside an HTML element is different and less useful for you.
But command
Select to brace is still not exactly what you would like to have even with the customization of the brace strings in wordfile for HTML. For example on having selected already a list item (element
LI) of a list or a table row (element
TR) of a table, a hit of
Ctrl+B results in selecting next
LI respectively
TR element instead of the entire list or table.
It would be necessary to write an UltraEdit script for the same behavior as in Dreamweaver which is executed by hotkey. That script is definitely not easy to code. It would require real language knowledge, i.e. what can be the parent element of currently selected inline or block element if there is already a selection on execution of the script which takes also current element level into account.
See also my post
Finding matching HTML/XML tag and the posts linked there.
