Background Colors for read only files
PostAug 18, 2006#1
I see there is a lot of control over color in UE, but I don't see what I need.
I often open reference files as read only. It would be great visual aid if I could have the background color for read only files be a differenct color then the ones I am actually editing.
Is this something I can configure?
344
PostAug 18, 2006#2
Asap no way !
Ask IDM for a feature request if you think this was important.
rds bego
6,826625
PostAug 19, 2006#3
Have you noticed that a read only file shows R/O in the status bar at bottom of the window.
And if you have the command Edit - Read Only (Toggle Read Only) in the toolbar you also can easily see if the current file is read only or not.
This maybe helps you although a different background color setting for files currently read only would also be a good idea.
PostOct 13, 2006#4
Yeah, I would like to see such a feature.
Another option would be to show the file icon in UE explorer with a lock or in a different color.
7
PostApr 14, 2010#5
This feature was added with UltraEdit v16.00 and UEStudio v10.00, which I find very useful.
