Matching IF - ENDIF with lines
PostAug 06, 2008#1
There's an official word for lines that are in the left margin of code that match an IF with the appropriate ENDIF.
Whatever that is, is there a way to do this with UltraEdit?
6,826625
PostAug 06, 2008#2
Are you talking about preprocessor directives or statements/keywords? In some languages IF - ENDIF are statements/keywords, in other languages these are preprocessor directives.
However, you can use Search - Match Brace to find the matching statement/keyword/directive. You just have to add these 2 words to the list of open and close brace strings in your syntax highlighting wordfile for the language used to highlight your source files.
Open Advanced - Configuration - Editor Display - Syntax Highlighting and press the button Open right to the file name of the syntax highlighting wordfile you currently use, if you don't have open a project with a project specific wordfile. Close the configuration dialog with button Cancel.
Find the line which starts with /Lx"..." with x is a number in the range of 1 ... 20 and "..." is the name of the language you see in the status bar at bottom of the UltraEdit window or in menu View - View As (Highlighting File Type) when one of your source file is the active file.
Between this language definition line and the line starting with /C1 you should see something like following:
/Open Brace Strings = "{" "(" "["
/Close Brace Strings = "}" ")" "]"
If you can't see these lines, insert them above the line starting with /C1. Next modify it to:
/Open Brace Strings = "{" "(" "[" "IF"
/Close Brace Strings = "}" ")" "]" "ENDIF"
Save the wordfile and you can immediately test, if command match brace now works for IF - ENDIF too.
Additionally I suggest to specify IF and ENDIF also as code folding keywords.
/Open Fold Strings = "IF"
/Close Fold Strings = "ENDIF"
or maybe even better
/Open Fold Strings = "IF" "ELSE"
/Close Fold Strings = "ELSE" "ENDIF"
Now you can easily fold (make hidden) all lines between matching IF - ELSE, ELSE - ENDIF and IF - ENDIF statements/keywords/directives.
For more details see in help of UltraEdit the page about syntax highlighting and the readme topic in the syntax highlighting forum.
236
PostAug 06, 2008#3
Perhaps what he means is to have fold regions marked by a line in the left margin, like this:
I don't think that's possible with UE.
PostAug 06, 2008#4
pietzcker -
That's exactly what I am looking for. It would be GREAT if UE would have this option with the ability to print.
For very lengthy programs it would be a life-saver.
Considering that UE can help identify matches already, the addition of a line to the left that is printable seems doable...
I'm really surprised that no one has done this yet.
PostSep 04, 2008#5
I'm also looking for a way to highlight syntax matches for HTML tags. Folding is useful in some cases but most of the time I just want to see highlighted text
In wordfile.txt, In the section that starts with,
/L3"HTML" HTML_LANG
I added,
/Open Brace Strings = "{" "(" "[" "<div"
/Close Brace Strings = "}" ")" "]" "</div"
Auto syntax highlighting is turned on.
PostJul 21, 2009#6
New version 15.10 -
Cool stuff, but disappointment when it comes to IF/THEN (logic) "staples". (see pietzcker above)
I can collapse code, yes. But I can not visually see nested loop lines - I have notches, but they do not indicate which IF matches an ENDIF.
Not only that, but it still doesn't print!!
Please, please consider giving us a more robust logic staples that actually match & print....
7
PostJul 24, 2009#7
It would be really great if folded code could have the option of having the entire line highlighted so that it is not so easy to delete the folded code.
