How to turn off annoying box poping up while typing?
PostMar 13, 2005#1
I am a newbie to UltraEdit 11.00a, although I have used earlier versions.
When typing, an annoying box is appearing immediately to the bottom right of the typed character. As I continue to type, it moves to keep this position with each character entered.
Since I don't know what this box is called, or supposed to do, and clicking in it doesn't seen to achieve anything useful, I am having problems trying to identify what it is, and how to disable it.
Can anyone please offer some insight here?
6,826625
PostMar 14, 2005#2
I think, it is auto-complete.
Open Advanced - Configuration - General, go to section Editing and turn off the last setting named Show auto-complete dialog automatically.
PostMar 14, 2005#3
You are quite correct, thanks for such a prompt response!
Initially the auto-complete option was not set, so I set it. Predictive words now began to appear in the box. When I then disabled the option, both the text - and the box - have now disappeared.
Is this a known minor bug?
80
Advanced UserAdvanced User
80
Re: Re: How to turn off annoying box poping up while typing?
PostMar 14, 2005#4
This is how it's supposed to work. Ctrl+Space will bring up the box on demand.
