Hex edit: Can't use command undo (UE 22.20.0.34)
    Oct 16, 2015#1
    Hex edit: Can't use command undo (UE 22.20.0.34). The Undo command in menu Edit is gray. Undo works in text edit mode.
    6,673580
      Oct 16, 2015#2
      Undo feature is by design not available in hex editing mode as it can be seen at top of menu Edit where all 3 undo related commands are disabled with file opened in hex editing mode or when switching for a text file from text to hex editing mode. If the file was opened with usage of a temporary file, the command File - Revert to Saved can be used to undo all modifications since last save.
        Oct 16, 2015#3
        Can I ask why designed this :?:
        6,673580
          Oct 16, 2015#4
          You can ask, but as I'm also just a user, I can't answer it. This is a user-to-user forum.
          Undo feature was never available in hex editing mode since first version of UltraEdit supporting hex editing which means since more than 15 years.
          481
            Oct 16, 2015#5
            Request an enhancement. Sounds useful.
