I'm using UEStudio '16 (x64) version 16.20.0.6, although I have noticed this problem for a while now, since the first 64 bit version I think.
I use Find & Replace quite often and occasionally find that the Replace with history has been cleared. The Find what history still keeps getting longer until I clear it though.
Clear recent document/project and search/replace histories on exit is unchecked in configuration.
It doesn't happen every time I exit (I'm not even sure that is when it happens), but it happens quite often and so far I haven't been able to put my finger on when or what makes it happen.
It isn't a big deal but it is quite annoying, especially when I have constructed a Regular Expression string to reuse. I know I can save them as Favorites but I often only need them until I have finished working on a set of files (and I forget).
Has anybody else noticed this or does anybody have any suggestions?
