Does UES lock files when opened?
29
    Nov 08, 2017#1
    We are noticing that UES (UEStudio '16 Windows 10 64-bit) may be locking files when they are opened.
    When we open a file on a network share (J:\myfile.txt) and then on the server try to overwrite the file (e.g. with COPY) we get:
    The process cannot access the file because it is being used by another process.
            0 file(s) copied.
    As soon as we close the file in UES the problem goes away. We are not technically "editing" the file - we have made no changes and are just viewing it.
    When does UES decide to lock?
    Is there any way to efficiently manage this? I.e. late locking?
      Nov 08, 2017#2
      A file is opened with a write lock if being opened without usage of a temporary file. Large files with more than 50 MB are opened without a temporary file with default settings. The appropriate settings for temporary files usage can be found at Advanced - Settings or Configuration - File handling - Temporary files.
      Further there is the setting Lock file for write while editing at Advanced - Settings or Configuration - File handling - Miscellaneous. This setting is not checked by default. But if this setting is enabled, every opened file is locked for write access by other applications.
      Please note that UltraEdit is a text editor and not a text viewer. Applications like file manager Total Commander with built-in listener to just view files are usually a better choice for just viewing files instead of an editor. The listener of Total Commander is available as free stand-alone application for people who just need a simple viewer for any type of file of any size.
      79
      Advanced UserAdvanced User
      79
        Nov 08, 2017#3
        I wonder if the "Read-only" setting for the file might help?  The OP can maybe try opening the file as "Read-only" (in the File/Open dialog click the down-arrow on the "Open" button to choose "Open as read-only", use the "Edit/Read-only" menu item, or click on the "R/W"/"R/O" gizmo in the status bar at the bottom of the UES window to toggle the state.  Perhaps UES will release the write lock in such a scenario?
        And if that doesn't work, it seems like it would be a reasonable feature request.
          Nov 09, 2017#4
          A late locking working by first opening any file always without a write lock and later on first modification establish the write lock is not really possible from a object-oriented program code point of view. It is not impossible, but it would be hard to implement and would have a negative effect on performance.
          More easier to implement without a negative effect on performance would be the suggestion of mwb1100 to open a file with File - Open with enabled option Open as read-only always without a write lock even if the file is opened without usage of a temporary file or when the write lock setting is enabled. When the user later decides to toggle off read-only mode, the read-only opened file could be closed and re-opened this time with write lock. Disabling read-only mode would be in this case refused by UltraEdit if the large file has to be re-opened without usage of a temporary file or the file should be opened now with a write lock independent on file size and this is not possible because another application has the file already opened with a write lock. Otherwise the switch from read-only mode to editable mode would be permitted by UltraEdit.
          But such a special file handling for files opened via File - Open using Open as read-only option or from command line with using command line parameter /r is not supported at the moment by UE v24.20.0.44 and UES v17.20.0.15. So this enhancement have to be requested by email to IDM support by a group of users.
