Command Close HTML tag is not working correct in UEStudio v21.00.0.66 (fixed)
6
PostMay 27, 2021#1
I use UEStudio v21.00.0.66 which is the currently latest version of UEStudio. But this version has one fresh problem fresh which is the command "Close HTML tag". It does not work correct anymore.
Example:  Suppose <ref> tag is open. Then I use command Close HTML tag. There is inserted now <%/ref> instead of </ref>.
How to solve this problem?
PostMay 28, 2021#2
I can reproduce this problem. It looks like a bug in program code of UEStudio which must be reported by email to IDM support and which I have already done. We have to wait for a new version of UEStudio which fixes this bug. There are affected only UEStudio versions 21.00 up to build 66 by this bug. The command works fine In versions of UEStudio < 21.00.
6
PostMay 28, 2021#3
Thanks Mofi
PostAug 15, 2021#4
The bug is fixed with UEStudio v21.00.0.90.
