There is the
Pieces blog
How to Run an LLM Locally with Pieces? It contains information about required hardware resources.
Running
local a LLM solution requires of course more than a standard user PC offers. It must be a
developer PC with a powerful GPU with much RAM (8 GB and more), a powerful CPU with lots of cores (8 or more), lots of RAM (32 GB and more) and lots of storage media (NVMe with at least 500 GB free storage space). Please note that the technical data posted here are my own guesses about the hardware requirements for efficient usage of
Pieces after participating in the webinar about usage of
Pieces in UltraEdit. I have not yet installed
Pieces and cannot share for that reason my experiences on
Pieces usage.
There must be created a database by
Pieces after installation depending on the
Pieces default configuration parsing local files according to the configuration. That takes initially heavy hardware resource usage until the database is setup and all the local files are parsed by
Pieces. Do not wonder on heavy hardware resource usage after installation and first execution of
Pieces as that is normal. The more files are stored locally (in documents, in cache of the used web browsers, source code files …) the more hardware resources and the longer it takes to build initially the database(s) for the configured LLM(s).
