Using Microchip MPASM with UES
6
PostDec 07, 2013#1
Hello. I'm using UES 11.10.0.1003, and would like to launch the Microchip MPASM PIC assembler from the Build toolbar. I have read the help file about adding a new compiler, and it seems complicated. I also looked at the Microchip C compiler configuration file as an example..
As instructed by the help file topic, Adding A New Compiler, I created a Microchip MPASM Assembler directory in UES_PATH\Configs\ and saved an empty PIC Application file in it. The help file then says, "...when the configuration file is completed, the added directory and file names will be used to populate the compiler list in UEStudio when the Edit Configuration button is pressed in the Select Compiler dialog."
This makes sense to me. The help file also says, under the Select Compiler dialog section that if I open that dialog, I can edit the compiler configuration file. But the Select Compiler button on the menu is disabled -- I can't get to the dialog!
I had an old version of UES (or UE) launching MPASM, so I know it can be done, but the configuration apparently was lost over several upgrades and a new computer.
Is there a config file for the Microchip MPASM that I can download and use?
If not, can anyone suggest a way to add this assembler to UES?
Thanks for any help.
--- Mike
PostDec 07, 2013#2
UEStudio v14.00 contains an Application file for Microchip C Compiler.
# ----------- Microchip C configuration ------------
# --- general --------------------------------------
# $P  - project name
# $Pp - path to project directory
# $Pn - project name
# --- compile --------------------------------------
# $I  - input full name
# $Ip - input path
# $In - input name
# $Ie - input extension
# $O  - output file
# $Op - path to output file
# $On - output filename (without path)
# $Oe - output extension
# $R  - release/debug setting for compiler
# --- build ----------------------------------------
# $T  - target full name
# $Tp - target path
# $Tn - target name
# $O  - output file
# $R  - release/debug setting for linker
[Settings]
Target =
Category&01 = DEFAULT RUN CONFIGURATION
Working Directory =.
Category&02 = COMPILER OPTIONS
Memory Model = s|l
Linker Script =
Compiler = MCC18
Linker = MPLINK
Excluded Files = Excludes
Compiler Options = -Opa-
Linker Options =
Debugger=
[SettingsInfo]
Target = Provides a space for you to specify an output file and location of the program that the linker creates.
Working Directory = Provides a space for you to specify the directory in which executing occurs. If you do not specify a directory, executing occurs in the directory where the executable is located.
Excluded Files = This will exclude the file(s) included in this UE project group from the build.
Compiler Options = Provides a space for you to specify an additional compiler options.
Linker Options = Provides a space for you to specify an additional linker options.
Memory Model = s-small, l-large.
Debugger=Provides a space for you to set the debugger you want to use to debug application.
[Variables]
CPATH =C:\MCC
MCC = $(CPATH)\BIN\$(Compiler)
MCL = $(CPATH)\BIN\$(Linker)
LINKSCRIPT = $(MCC)\LKR\$(Linker Script)
UPLOADER = Z16080Upload.exe
[Environment]
[General]
TargetExt = .EXE
ReleaseOut = Release
DebugOut = Debug
UseFullPaths = 0
UseDosNames = 1
Excludes = $(Excluded Files)
[MakeCommands]
upload = Upload Application
debug=Start Debugger
makef=Show Makefile
[Upload Application]
Title = Upload $T
Cmd0 = $(UPLOADER) $T
Depends = $T
ShowWindow = 1
DisplayConsole = 1
[InsertFiles]
[FileGroups]
FGO = .o;
[GroupFormats]
FGO = %s
[Build]
Out = $T
Depends = $FGO
Cmd0 = $(MCL)\MPLINK $(Linker Options) /m $On.map /o $O /l $(MCC)\lib $(LINKSCRIPT) $FGO
[.C]
Out = $In.o
ReleaseFlag = -O
Cmd0 = $(MCC)\BIN\$(Compiler) -w2 -m$(Memory Model) -p=18C252 -i$(MCC)\H $R $I
[Start Debugger]
Title=Debug $T
Cmd0=$(Debugger) $T
Depends=$T
ShowWindow=1
[Show Makefile]
Title=Show makefile
Cmd0=uestudio $(UESMAKEFILE)
ShowWindow=1
DisplayConsole=0
You need to change
  • parts of group [Settings] as you most likely want assembler instead of C compiler options available for selection,
  • parts of group [SettingsInfo] according to the changes in group [Settings],
  • you may want to add a variable in [Variables] for calling the assembler executable,
  • group [.C] needs to be replaced by a group for your assembler files with extension .ASM or whatever is used for your assembler files with adapting ReleaseFlag = and Cmd0 = for the assembler,
  • and last the comment in the first line should be also modified for completness.
The Select Compiler command is disabled as long as you have not created an UEStudio project. So you must first execute Project - New Project/Workspace - Create New Project and configure the new project by specifying a project name, selecting the projects directory, adding your assembler file(s) to the project, and select already now the compiler respectively assembler on Settings tab using button Set/change compiler.
