Hi UEStudio experts,
I am a newbie. I was able to create a custom makefile using mingw32-make.exe instead of the internal mymake.exe. When I created the project in UEStudio, I had to pick either the debug directory or the release directory for my build. I also configured the MakeTool = MyMakeTool.bat option correctly in the select compiler section. However, when I try to build using the custom makefile, the build and rebuild only work if I put all my source files and my custom makefile in either the debug directory or the release directory (depending on how I wanted to build). But if I kept my source files and my custom makefile in the project directory instead, the build complains it cannot find the makefile and the source files. I know there must be an easy solution without putting some awkward syntaxes in the makefile such as ..\filename etc., please help. Finally, my custom compiler is in the c:\MinGW\ and c:\MinGW\bin\ and are also configured correctly. Thanks in advance.
All my source files and the custom makefile is stored in the directory c:\idddbmp\
MyMakeTool.bat contains the following lines:
my custom makefile contain the following lines:
@echo off
Path=c:\idddbmp;C:\Program Files (x86)\IDM Computer Solutions\UEStudio\;%PATH%
mingw32-make.exeCode: Select all
default: tsapnd.exe
tsapnd.exe: tsapnd.c
g++ -Wall tsapnd.c -lm -o tsapnd
glbxapnd: glbxapnd.c
gcc -Wall glbxapnd.c -lm -o glbxapnd
ibkapnd: ibkapnd.c
gcc -Wall ibkapnd.c -lm -o ibkapnd
glbxcmd: glbxcmd.c
gcc -Wall glbxcmd.c -lm -o glbxcmd
glbxrun: glbxrun.c
gcc -Wall glbxrun.c -lm -o glbxrun
